Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Integra & 97-01 Integra Type-R (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r-17/)
-   -   Code 43, can't figure it out!!! (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r/189971-code-43-cant-figure-it-out.html)
G2teg_driver May 19, 2005 08:53 PM
So i have been dealing with this problem for about 6 months. I am getting a code 43 in my 91 GS teg b18a1 OBD0, In my manual it says that it is a an oxygen sensor problem or a vacume leak. I have noticed a loss of power. When i am driving around town the CEL does not come on but if i am above 3000 RPMs for over a minute it will come on. So far I have replace the Oxygen Sensor, Vacume Tubing, Fuel Filter, checked all my grounds. Could my ECU be bad? How could I check? Please help.
davidc425 May 21, 2005 06:30 PM
check fuel pressure.
davidc425 May 21, 2005 06:31 PM
could also be dirty injectors and intake caron build up in the intake manifold.
coltank May 21, 2005 09:28 PM
Is that the only code you're getting? I got that on mine, but was also getting one for the map sensor. Replaced it and all was fine
G2teg_driver May 24, 2005 05:38 PM
i installed an adjustable fuel pressure regulator and have it set to 52psi, stock is 41-48, and i have also ran injector cleaner. I also removed the fuel rail and injectors and cleaned and inspected them, everything looks ok, this is why I am stumped.
coltank Aug 10, 2005 10:04 AM
did you ever figure anything out with this? I am having the same problem.
© 2026 MH Sub I, LLC dba Internet Brands
