Temperature Guage
Old May 19, 2005 | 06:33 PM
SmilinT's Avatar
SmilinT
Default Temperature Guage
Hey folks, I just purchased an '87 Acura Integra DOHC..the temperature guage hovers at about half way to hot. Is that normal or should I have it checked? What could it be? Also, when I turn on the AC I do not get cool air..it is warm air..could it be the AC needs to be serviced or replaced. Need a few suggestions before I go to the mechanic and have him complete the work...
Old May 19, 2005 | 07:05 PM
Takumi Fujiwara's Avatar
Takumi Fujiwara
The temperature gauge should sit around the middle between C & H. And your A/C... it may be leaking because it theoretically, it should not leak the R34 or freon... whatever your's uses. If you buy a self charge kit, you could try filling it and see if you can hear it leaking anywhere.
Old May 19, 2005 | 08:57 PM
EviLLLLSiNz's Avatar
EviLLLLSiNz
n00b
yea your temp is ok.. just keep an eye on it and make sure it doesnt go up.. if it does, turn on ur heaters full blast, it cools the engine. when you start up your car it should point at "C" tho, since it isnt even warmed up.
as with the a/c, its broken and u need to get it fixed with a mechanic or somethin.
Old May 20, 2005 | 10:55 AM
Tobra's Avatar
Tobra
Mine runs below the middle when warmed up, look at the radiator, if it is all plugged with bugs and stuff, that is no good. Also may need to flush cooling system. AC may just need charging, or something more expensive
Old May 29, 2005 | 03:10 PM
SmilinT's Avatar
SmilinT
Thanks everyone for the advice...I will get my AC looked at and make sure my radiator is clean....will let you all know how things go..
