Struts/Spoiler Light
Old May 19, 2005 | 06:26 PM
HmGDuD's Avatar
HmGDuD
Default Struts/Spoiler Light
I have a '96 Integra LS Coupe and badly need to replace all 4 struts. I called up Sears and the struts cost 72.74 each but the final price came out to be 578 dollars for them to do it. Is it relatively easy for me to replace the struts myself, or am I better off if some mechanic do it (I really don't feel like paying 578 dollars to Sears)?
Also, my spoiler LED light panel is dead. I looked at the price of the part at Acura's website and it came out to be 200 something dollars just for that simple LED panel (I'm sure it cost no more than 20 dollars to manufacture). Where can I buy one for a reasonable price?
Thanks!
Old May 19, 2005 | 08:47 PM
EviLLLLSiNz's Avatar
EviLLLLSiNz
n00b
id rather just get some koni yellows for 600 bux and install it myself... :P with that kinda money u can get better shocks for cheaper and it shouldnt b too hard to install from what ive heard (some good choices would be tokico, kyb, or koni). there are guides on installing shocks just search. The led light... did u check ebay? they might have somehting. if not why dont you check out a junkyard.
Old May 19, 2005 | 09:28 PM
mdaman's Avatar
mdaman
you can just buy a replica spoiler with an led light for like $70 shipped (ebay) if you really want the light that bad. Also check all of your grounds and connections.
Old May 19, 2005 | 10:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Here is a basic rundown of the process involved with changing out your struts.
http://www.c-speedracing.com/howto/c...r/coilover.php
Keep in mind that they are installing coilovers but it gives you a good idea of what needs to be removed to get the strut assembly out. If you have the tools, you might as well save yourself over $200 and do it yourself with better struts than the ones they would give you.
Old May 20, 2005 | 07:35 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
yeah i'd replace your struts yourself but if your rear struts haven't been off yet you might run into some problems because the bolt usually seizes inside the bushings in the rears.
Old May 20, 2005 | 09:08 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Struts can be in involved process, but as long as you follow the instrucitons step by step, it's not that bad. The worst parts are dealing with the lower LCA bolts and compressing the springs, but beyond that, it's easy.
