Need help! caliper piston
Old May 11, 2005 | 03:08 PM
FASTER's Avatar
FASTER
Default Need help! caliper piston
Im changing the pads on my 01 gsr and was wondering how does the caliper piston go back in cause my new pads are huge compared to what was in before.
Old May 11, 2005 | 03:12 PM
Carfan1's Avatar
Carfan1
You just squeeze it back in unless the caliper piston has slots in it. Then it might require to be twisted back in.
Old May 11, 2005 | 03:14 PM
FASTER's Avatar
FASTER
Its not going back in when i try.
Old May 11, 2005 | 03:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have to get either a c-clamp or brake piston compressor to push it back in. You cannot use your bare hands.
Old May 11, 2005 | 03:46 PM
Provocateur
On permanent hiatus
If it is the rear piston, a flat head screwdriver can be used to screw it clockwise back into the cylinder.
Old May 11, 2005 | 04:50 PM
dubcac's Avatar
dubcac
I
For the fronts I used a C-clamp to depress the piston.
Old May 11, 2005 | 06:19 PM
newgsrdriver's Avatar
newgsrdriver
Fronts are pressed in...c clamp works great.
Rears turn in. Screwdriver, pliers...anything you can use to turn the piston in.
Old May 12, 2005 | 01:45 PM
FASTER's Avatar
FASTER
Thx
everything worked out, i just used a c clamp and i was on my way. thanks
