Idle prob
Old May 5, 2005 | 10:39 AM
renesuzan's Avatar
renesuzan
Default Idle prob
I,m new here but I feel I will find real help here. Ok, I,ve a teg,92 ZX dual carb....having prob with idle...checked the IAC but still having probs+ i,ve black spark plugs in 3 And 4. When I start my A/C the idle goes from .8 to 1.4! I on tuning perhaps since my birth! need some suggestion guys. thanx.
Old May 5, 2005 | 11:04 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
vaccum leak? check your hoses and make sure they're intact with no cracks.
Old May 5, 2005 | 11:19 AM
renesuzan's Avatar
renesuzan
Nope, no vaccum leaks apparently.........well can u tell the easiest way to check for leaks. And idle reset.........people say diff things...pretty confusing.
Old May 5, 2005 | 01:57 PM
'93TurboD's Avatar
'93TurboD
5-finger discount :rick:
800 RPM sounds about right. I don't know exactly what your problem is. When you turn the AC on idle goes up? That's normal, the AC compressor puts the engine under load. When the car senses load it raises the revs to keep the car from running rough.
A vacuum leak would cause a high idle. Is that what your problem is? Or does it fluctuate? Are your spak plugs new? How about the rest of your ignition?
If you're just worried about idling @ 800 RPM then turn the idle screw to adjust it. Sorry I'll need more info to help more thoroughly.
Old May 6, 2005 | 05:28 AM
renesuzan's Avatar
renesuzan
I,ve prob when i push A/C. It goes 1 to 1.5 or more ultimately... perhaps I need to clean my IACV valve. Plus i need information about correctlty reseting my ECU computer.
And what should be the cold start rev upto? is it 1.5 or 2 ...donno. If i knew i colud adjust.
Old May 6, 2005 | 05:43 AM
Epoch's Avatar
Epoch
Never cleaned my IACV, so I'm not authoritative on how to do it, BUT the ECU reset is easy. Pull the backup fuse from the engine bay, and leave it out for 15 minutes. Replace the fuse, then start the car. Let it idle for another 5-10 minutes with no accessories running, until the engine's fully warm, then turn off the car. The ECU reset procedure is complete
Old May 6, 2005 | 10:44 AM
renesuzan's Avatar
renesuzan
i'm going to reset my ECU tomorrow. But 1 thing for sure ...will it in a hot engine or cold start?
Thanks for yr time.
Rene
Old May 6, 2005 | 10:51 AM
Epoch's Avatar
Epoch
Thanks for yr time.
Rene
I've always done a ECU restart on a cold engine, but I don't think it matters much.
