Last Resort: What is Wrong With My GSR?
Old Apr 17, 2005 | 07:17 AM
slammedgsr95's Avatar
slammedgsr95
JDM GSR
Default Last Resort: What is Wrong With My GSR?
I've had the car for about two months. When I first bought it, it refused to start up the first time, it would start up and then die and then go on right away at the second try. It worsened, then sometimes when I would press on the gas while driving it wouldn't give me any power,gas,spark whatever it is and I wouldn't go anywhere, about a second later it would throw me forward in my seat as I finally got a spark or whatever it might be. It would do this 3-4 times in a row. It finally got so bad that I stalled going 50 MPH and wouldn't start back up. Took it to my mechanic, and he put in a new rotor. Problem went wrong and two weeks later I was back in the shop. This time he put in a new rotor and dizzy cap. Guess what? Went bad again in another two weeks so I decided to go to Honda because they assured me that they would know what's wrong with it.
I take it to Honda and they look at it for THREE HOURS, and they can not find a thing wrong. They tried everything and then they finally looked at my plugs and realized that my plugs were very worn down and non-platinum. So they threw in some new plugs.
SUPRISE! Three weeks later it does the previous thing it did, where I'd press in the gas and not go anywhere. I'm debating on selling this thing because not one shop knows what's wrong with it. Does anyone have an idea?
Old Apr 17, 2005 | 10:00 AM
jamesmeister's Avatar
jamesmeister
throttle position sensor maybe?
Old Apr 17, 2005 | 12:11 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Couple of things u wanna look at.. Your plug wires.. should be at least 7.5mm i'd run 8.5 or 8.0 but 7.5 will do, Secondly take a look at your timing buddy.. make sure the cams are lined up correct in the "up" position take a wrench and bring it to TDC and line it up thirdly check your igitior and coil.. Its one of those things i promise i had the same problem but it was my coil and what not but if ur timing is off man, your car could be in some serious trouble.. hope that works.
Old Apr 17, 2005 | 12:44 PM
fergy016's Avatar
fergy016
are you obd2? Using the ecu that came with the engine? Throwing any cel error codes? take the valve cover off, set the crank to the white line to the line that is angled on the timing belt cover and make sure the cam gears line up with the marks on the gears(checking that your not a tooth off). Also if you have a timing light, connect it up to plug #1, by the crank and see if it hits the white line on the crank to the line on the lower timing belt cover.
Old Apr 17, 2005 | 12:54 PM
slammedgsr95
JDM GSR
The idiot guy who swapped the motor put in a mugen ecu. And no, it isn't throwing any codes.
Old Apr 17, 2005 | 04:19 PM
fergy016's Avatar
fergy016
I am not sure what is done to a mugen ecu. Not sure if it will still throw a code like a normal ecu. Well check the timing and see if that is the problem, otherwise I have a feeling it is electrical(being tps/coil,etc), or lack of fuel pressure.
Old Apr 18, 2005 | 05:33 AM
IntegraType-R
ALL MOTOR KING
gotta be timing get rid of that pos mugen shit and get some real tuning bro those jun/mugen chips are a waste of oil changing money.. get a stock p72 ecu and run a stock rom and go from there i'm sure ur timing's off man its gotta be even if its off a tooth it'll kill that thing to bits..
Old Apr 18, 2005 | 05:51 AM
DiAbLo3785's Avatar
DiAbLo3785
Working on project CRX Si
is ur car standard or automatic?
Old Apr 18, 2005 | 06:11 AM
carta79's Avatar
carta79
Life after death
I remember your running rich thread, you're still using that ECU. It's not the cars fault for running improperly. The person who setup that swap should be hung by his balls.
Old Apr 18, 2005 | 07:58 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Has anyone checked the ignition coil to see if that was in spec?
