special kit or bracket for type r rear sway bar on LS
Old Mar 14, 2005 | 01:12 AM
keefungliu's Avatar
keefungliu
Default special kit or bracket for type r rear sway bar on LS
i wanna put a type r rear sway bar on my ls. but i heard it will tear off your sub frame if you don't install it right. is any special kit or bracket out there i can buy to ensure the safety? thanks.
Old Mar 14, 2005 | 04:10 AM
99IntegraGS's Avatar
99IntegraGS
These are the three options I know...
BSQ subframe reinforcement kit (http://www.geocities.com/bretq/mounting_kit.html)
BEAKS subframe reinforcement kit (http://www.beaksproducts.com)
COMPTECH tie-bar/subframe reinforcement (http://www.comptechusa.com)
BSQ - $20-25
BEAKS - $65
COMPTECH - $190 on eBay, seller aofeparts
Personally, I have the BEAKS kit, but I am considering changing to the COMPTECH piece. Since I have already installed the BEAKS kit (which means removing a tack welded nut) I will probably have to continuie using the back half of the BEAKS kit.
JD
Old Mar 16, 2005 | 12:50 AM
keefungliu's Avatar
keefungliu
i wanna change to competch too. they have the combo for tie bar and sway bar. but since i have a dc tie bar already. i don't wanna take it off.
Old Mar 16, 2005 | 04:53 AM
reno96teg's Avatar
i have the BSQ kit, and i've had it for at least 2-3 years now. so far no problems. easier to install than the beaks kit. however, the beaks kit is a bit nicer looking, and appears to reinforce a bit better, although i've not heard a single problem with running the BSQ kit. and, it's less than 1/2 the $$.
Old Mar 16, 2005 | 08:38 AM
b00gers's Avatar
b00gers
:werd: The hardest part of the install was putting the bar on by yourself. And with the BSQ kit, you also have to drill holes. So make sure you are comfortable with that.
http://b00gers.com/testing/ITRinstall.htm
Old Mar 16, 2005 | 09:35 AM
ISP James's Avatar
ISP James
DAMIMRED
yeah im not about to drill or chisel my car, i was leaning much further toward the comptech tie bar.
