oxygen sensor problem
Old Mar 12, 2005 | 02:36 PM
danteisme's Avatar
danteisme
Default oxygen sensor problem
my 96 gsr threw a code 65(2ndary sensor) so i replaced it. i started it up after i cleared the code and about 3 seconds later it through the same code. what do i check for now?
Old Mar 12, 2005 | 03:02 PM
teg92's Avatar
teg92
WHAT OK YEAH!
could be your cat
Old Mar 12, 2005 | 03:48 PM
dubcac's Avatar
dubcac
I
Are you sure you replaced the correct oxygen sensor?
Old Mar 12, 2005 | 04:03 PM
danteisme's Avatar
danteisme
well, the cat isnt even 8 months old yet so i hope its not taht. and i know its the right sensor becuase i unplugged the front one and then it threw the code for the front(code 30something) as well as the rear.
Old Mar 13, 2005 | 07:43 AM
danteisme's Avatar
danteisme
ok, ima give some more insight to hopefully find a solution for this problem. on the first sensor, as soon as i reset the ecu it would immediately throw the code. now with the new sensor, it waits about 3-5 seconds then shows up sayin the same code 65. heres a thought i just had. what are the signs of a cat goin bad? i have a catco hi flo cat(on there since july 04) BUT, i did notice somewhat of a sulfar smell sometimes under somewhat heavy acceleration, and i did also notice a rattling sound between 2500 - 3000 rpms. could a potentailly bad cat cause this code to come up?
Old Mar 13, 2005 | 08:10 AM
carta79's Avatar
carta79
Life after death
The rattling may be due to the welds for the heatshield coming loose on the cat.
What brand sensor was used?
Was the ECU reset?
Here's some info from team-integra that may or may not be your problem.
The oxygen sensor measures the amount of oxygen present in the exhaust gas. Depending on the voltage generated by the oxygen sensor, the engine management system will change the air/fuel ratio to obtain the desired oxygen level present in the exhaust gas. A malfunctioning oxygen sensor sending an erroneous reading to the engine control system can cause a too rich or too lean condition. A rich condition will cause the converter to overheat and melt down from the unburned fuel being ignited while a lean condition can result in a misfire that can lead to the same result. Oxygen sensors wear out and need to be changed per your auto manufacturers time and mileage limits.
Old Mar 14, 2005 | 06:49 AM
danteisme's Avatar
danteisme
i used an oem sensor, and reset the ecu, but it acts differently with this new sensor in. with the old sensor, after i reset the ecu and restarted the car it would immediately pop a CEL light. with this new one it waits a good 3-5 seconds to pop the code.
Old Mar 14, 2005 | 08:55 AM
dubcac's Avatar
dubcac
I
It's possible that there is something wrong with your cat then, and the sensor is reading something that the ECU doesn't like and throwing a code. The two oxygen sensors work together, so there is something happening between the first and 2nd sensor.
Old Mar 14, 2005 | 10:10 AM
carta79's Avatar
carta79
Life after death
I read somewhere that a blown alternator fuse could set off that CEL :dunno:
You should ditch it for a Carsound converter, they flow better then Catco converters.
Old Mar 14, 2005 | 04:05 PM
danteisme's Avatar
danteisme
u know what fuse that is? it doesnt say in that post and after lookin and the fuse list in my manual i cant find a fuse for the alt, etc...
