Originally Posted by red94teg
That makes sense, cause i've got Apexi WS and I can't hear vtec kick in, but on my buddies '99 GSR he has a test pipe and no muffler, so you can definitely hear it. It probably doesnt help that my vtec doesnt engage until around the same time as the secondaries open up anyway (somewhere around 6000 rpm). Oh yeah, what is the benefit to having vtec kick in this high? It was tuned that way when I bought the car.
your vtec shouldnt be set that high unless you have aftermarket cams, in which case I hear that the skunk2 stage 2's like to have vtec around 6k. |
I had ITR cams in there before but then I had to swap b16 cams in for a while, but I am getting ITR cams put back in in a few weeks... |
Originally Posted by mean-azz-acura
how bout vtec controllers, how do they work, and what are the pros and cons of having one? maybe vtec is tuned to open up when the horsepower levels and start to drop through the range, maybe thats why i dont really feel it, because its not really boosting the horsepower, just maintaining the power level where non-vtec usually drops off, which may be how the gs-r has a 8k redline that is practical. if im wrong, let me know, i know the basics of the function of the variable timing concept, but as far as hands on, though its my fourth teg, this is my first vtec...
Vtec contoller isn't bad, like the Apexi VAFC or the fields one, but the thing with those is if u have a bunch enigine work done then it makes a difference and they have there limitations, as for your stock set up your vtec kicks in at about 4500 rpms, but u really don't hear till u have the second runners open up @ 6000k. I have a apexi VAFC that i am going to be installing in a couple weeks along with my cam gears, and gettin it dyno tunned.. (01 GSR comptech ice box, comptech headers, skunk2 cams, skunk2 intake, apexi N1 exhuast.)
its actually engaged at 4400 rpms and the secondary butterflies open @ 5700 rpms
the same engine speed for normal single stage VTEC engagement in the ITR |
I thought i read some where that vtec engagement is at 5500 for a stock gsr, right or wrong?
I read 5600...
I read 5600...
vtec engages at 4400 and the intake secondaries open at 5700-5800. how many times does this have to be posted in this thread alone? :down: |
apparently many times...
my bad, i meant the secondaries, anyway. |
