old squeaker
when i go into turns my 93 gl starts squealing when i go straight again it stops???what could this be???
brake squealers... time for brake job...
Most brake squeeks arent actually due to the actual contact between the pad and the rotor, unless your pads are low in which case the pads are designed to squeel against the rotor at that point. If your pads are not low the squeeking could very likely be due to virbrations between the pad and where it mounts. If you are going to get new pads, make sure you put anti squeel all over the back of the pad. There is also antisqueel you can buy to spray on the rotor itself.
NO NO NO I have very good pads on it, I am starting to think maybe it is differential
fixed it
my power steering was low :rolleyes:
