integra 92 gs engine problem
Old Feb 9, 2005 | 05:47 PM
tmaoz's Avatar
tmaoz
Default integra 92 gs engine problem
Hi Integra folks
This problem in my Integra 92 GS 5 speed 161k.
I just did regular maintenance: oil change, air filter, and front brakes.
And everything looks fine it drive very strong for 161k but when the engine is working in neutral gear the rpm is okay, between 700 to 800 but not steady, it’s going up and down you can see it in the tachometer, and you can feel that the engine is not working nice and smooth.
What can be the reason?
Is it some vacuum hose (I check already, look fine)?
Is it some sensor? (The car just passed smog)
PCV valve?
Hope you can help me before I take it to a garage and spend my money
thanks tom
Old Feb 9, 2005 | 07:16 PM
JWC67896's Avatar
JWC67896
AZN Jim
Default Answers to your issues
How are you doing? As a fellow g2er i know what your talking about my other white teg had the same problem and since you are a 92 you have a obd2 and the issue lies within the o2 sensor being faulty you should go out and buy new ones i think they are only like 10 dollars or something and then bring it and get it replaced. and if that is not it i may be your pcv valve but i am almost promising its your two o2 sensors and although it passed the test that wouldnt effect the emissions. let me know what happens
Old Feb 10, 2005 | 09:37 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
92-95 = OBD1
96-00 = OBD2
Old Feb 10, 2005 | 10:08 AM
teg92's Avatar
teg92
WHAT OK YEAH!
92 Is OBD 1 and a o2 sensor does not cost $10.00 an OEM o2 sensor is over $75.00. And if it was a bad o2 sensor most likey there would be a CEL. I would double check the vaccum lines, and try cleaning your IACV
Old Feb 10, 2005 | 11:03 AM
fjm1's Avatar
fjm1
G35
Default advice
wow some advice just ain't worth the page it's written on.
Ditto on IACV cleaning.
Old Feb 11, 2005 | 08:26 AM
jkaszuba's Avatar
jkaszuba
ok if your going to post please know what you are talking about. research and apply what you learn. O2 sensors from your local auto store just buy the bosche non plug style for 35. Be smart about what you put into your car.
Old Feb 11, 2005 | 08:30 AM
teg92's Avatar
teg92
WHAT OK YEAH!
:werd:
