rattel
Old Feb 9, 2005 | 02:47 AM
edhud's Avatar
edhud
Default rattel
My, 1997 integra v-tech gsr, has a loud can sounding rattle in the front of the car when I hit about 3,000 rpm no matter what gear I'm in. My friend said it was the baffold. It runs perfect otherwise. Any suggestions.
Old Feb 9, 2005 | 04:49 AM
carta79's Avatar
carta79
Life after death
It's spelled vtec not vtech. I had a similar problem on my LS and it turned out to be the heatshields on the exhaust.
Old Feb 9, 2005 | 06:21 AM
GSRchick714's Avatar
GSRchick714
Probably heat shields....mine does that when I hit a little over 4500...unfortunately I haven't gotten under the car to fix it yet....
Old Feb 9, 2005 | 06:57 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Check the heat shields surrounding the catalytic converter and the exhaust manifold.
Obviously, use jackstands to support the car, and be careful not to burn yourself.
Old Feb 9, 2005 | 12:01 PM
Snoopy's Avatar
Snoopy
been there done that
the heatshields are almost always behind this notorious rattle on tegs. do you have the stock header? there is a piece inside the collector of the stock header that is known to break off and start rattling too. just giving you another possibility.
Old Feb 9, 2005 | 01:02 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
See, that's awkward, I have a 96 GS-R, and when I mentioned it, everyone suggested it's probably the valves. Mine even does it @ the exact same rpms...
like 3000-3500 then it goes away right?
Guess you and I both are gonna have to jack em up.
Old Feb 9, 2005 | 09:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is either the manifold or the heat shields. In my case it was the A-pipe of the manifold. Stock OEM replacement: $600. I said screw it and put a DC sports header on there.
