THE ABS and MR LIGHT IS ON??
Old Feb 2, 2005 | 10:00 AM
94acu_integ's Avatar
94acu_integ
Default THE ABS and MR LIGHT IS ON??
well, a month ago i had my springs cut about 2-3 inches by my buddies and after the work...my ABS (ANTI-BRAKE SYSTEM) light came on...what can i do to make the light go away? also how can i turn off the MAINTENANCE REGUIRED light off too?
Old Feb 2, 2005 | 10:41 AM
bigt61's Avatar
bigt61
ABS- no clue.
as for the maintenance light, on the guage panel there should be a slot near the amber light. stick your key in it.
Old Feb 2, 2005 | 12:19 PM
95LSDOHC's Avatar
95LSDOHC
to turn off the MR light you have to look under your steering column, your should see a little square blue button, if you hold this for like 15 seconds the light should turn off. I cant remember if the car has to be on or just the turn turned to battery, im sure if you try both you will figure it out
Old Feb 2, 2005 | 04:07 PM
94acu_integ
i'll give it a try
Old Feb 2, 2005 | 06:33 PM
brothalynchhung's Avatar
brothalynchhung
yea its under your steering colum panel near peddels just get on the floor and look up
