Keyless Entry Remote
Old Dec 27, 2004 | 08:07 PM
Gotti's Avatar
Gotti
The Don
Default Keyless Entry Remote
I recently bought a used Teg and it didnt come with the user manual. I was just wondering what the option button does and how to use it.
Also i must of pressed the option button by accident cause before, the top button would do silent keyless entry and the bottem button would do it with a honk. Now both of them are silent.
Old Dec 29, 2004 | 10:27 AM
Gotti's Avatar
Gotti
The Don
Come on... somebodies gotta know how to use the keyless remote. What does the option button do?
Old Dec 29, 2004 | 12:04 PM
VPUPPY's Avatar
VPUPPY
i believe if you press the option and lock button at the same time, it changes the mode(honk or no honk). if you look at the led light at the top you can see it flash. i believe one flash stands for honk and 2 flashes stand for silent.
the option was for other acuras that had a trunk soleniod and it is used for the above programming.
Old Dec 29, 2004 | 12:16 PM
99IntegraGS's Avatar
99IntegraGS
I just installed the keyless entry/alarm system a few months ago in my 1999 Integra. I'm not sure what the option button does, but I can list what the Operating Instructions manual says. Upon testing the OPTION button just a few minutes ago, I found mine does nothing. I have the "electrically driven unlock system", but I'm not sure what the instructions below mean by "electrically driven unlock system using accessories for the glass hatch or trunk". Mine only works for switching the arm and disarm beep on/off. My hatch will unlock when I press the unlock button on the remote twice, but then so do all my doors.
Controls and Functions
3. OPTION - When the OPTION button is pressed and held for more than one second, the hatch (or trunk) will unlock. (Functional only on the vehicles equipped with electrically driven unlock system using accessories for the glass hatch or trunk. For details, contact your ACURA dealer.)
4. OPTION Button - When pressed and held simultaneously with the LOCK button for more than 1 second, the confirmation "BEEP" feature is switched between on and off. The remote control indicator LED will flash once when the confirmation "BEEP" is turned on, and flash twice when the confirmation "BEEP" is turned off.
Not sure this will be of any help...
JD
Old Jan 31, 2005 | 07:08 PM
Gotti's Avatar
Gotti
The Don
I tried doing this and its not working out for me... it always just flashes twice and it stays silent
