having IDLE proplem need help pleaseeee
Old Dec 5, 2004 | 10:42 PM
nextphase's Avatar
nextphase
Default having IDLE proplem need help pleaseeee
hey i just hooked up my turbo to my integ... i dindt install fmic yets ima do it this weekend.. but my car been having idling problems like my idle be hella high... i just install turbo.. i never tuned it or adjust my timing... but what do u think the problem is and what should i do? is it normal to have the problem wen u install turbo.. some friend are sayin i just need to adjust timing? or does da fmic might play a key role in this.. i have just a greddy 18g turbo kit.. with stock everything liek da greddy blue fmu and 310 injectors... need help...
Old Dec 5, 2004 | 10:43 PM
nextphase's Avatar
nextphase
this is the car that got keyed.. i post previous threads ... fukin haters ...
Old Dec 6, 2004 | 02:20 PM
blueboi69's Avatar
blueboi69
hi, i had the same problem. One you have to replace your throttle body or right under your throttle body there are (3) 10mm screw and remove that piece and replace that with a another one. You could probably get that piece from another donor throttle body. I hope this help.
Old Dec 7, 2004 | 05:12 PM
nextphase's Avatar
nextphase
my idle is getting higher.. how much are those things ne ways?
Old Dec 7, 2004 | 05:17 PM
dubcac's Avatar
dubcac
I
Check your idle screw, and check your vacuum connections. Get your car tuned before you drive it and beat on it with that turbo, or you'll be sorry.
Old Dec 8, 2004 | 10:07 PM
nextphase's Avatar
nextphase
i tryed getting it tuned but i cant tune da greddy fmu that comes with the greddy kit... so tuning is out of picture... im gonna try the idle screws... im gettin worried my car is gonna get fuked ... so please give me more advices
Old Dec 10, 2004 | 09:36 AM
dubcac's Avatar
dubcac
I
You can still tune fuel pressure and timing. I would do that so you don't blow a motor. Check your vacuum connections, a vacuum leak can cause the idle you're experiencing.
Old Dec 10, 2004 | 01:35 PM
raykan's Avatar
raykan
check your IAC valve, is your idle only really high when your car is cold?
Old Dec 10, 2004 | 05:19 PM
nextphase's Avatar
nextphase
i messed with the iac valve and it went back to normal but soon again my idle would be high again and wen i dump in to neutrol its at 2000 rpm whys dat? so i can tune fuel pressure and timing? where is a good place in bay area? or how mnay hours do u think? can i bring it to a race tuning shop?
Old Dec 12, 2004 | 08:30 AM
blueboi69's Avatar
blueboi69
im telling you i had the same problem you have to replace that throttle body. Or you have to replace that bottom pieces of the throttle body because that part is probably clogged with dirt from your radiator. You could get it off a space integra or probably civic throttle body.
