Wheel bearing problems
Old Oct 27, 2004 | 03:27 PM
VersuS's Avatar
VersuS
Default Wheel bearing problems
Anybody replaced all their wheel bearing on 3d gen teg?
I own a 96 teg with 220 000 km and all the wheel bearing failed, one by one, at maybe 10 000 intervals. And now, the same noise again, the front left seems to be worn out again, about 10 000k after I've replaced it.
anybody experienced this??
Old Oct 27, 2004 | 03:54 PM
94civicEX's Avatar
94civicEX
I got worms.
Did you replace the whole hub or just the wheel bearing?
99 Integra GSR
06 TSX
duck squad member #00003
Old Oct 27, 2004 | 04:02 PM
VersuS's Avatar
VersuS
for the last one replaced, I've changed the bearing first and noticed a month later that when the technician replaced the bearing he damaged the hub so I had the replace the hub and put the bearing back in. The new bearing that was in the damaged hub didn't seem damaged so I put it in a new hub. Meanwhile I had brake problems and the whole wheel overheated a lot, so maybe the bearing overheated too???
Old Oct 27, 2004 | 04:09 PM
94civicEX's Avatar
94civicEX
I got worms.
It's possible. I'd never pull a bearing out and re-press it back in. I had to replace a wheel bearing and I just replaced the whole hub and I haven't had a problem
99 Integra GSR
06 TSX
Old Oct 27, 2004 | 06:01 PM
newgsrdriver's Avatar
newgsrdriver
Yep, done my left rear 2x now. And it sounds like it needs a 3rd, along with the right rear. Its annoying, but at least it isnt difficult.
Old Oct 27, 2004 | 06:09 PM
dubcac's Avatar
dubcac
I
I've never heard of people having problems by just replacing the wheel bearing instead of the entire hub...just make sure its done correctly and you should be fine.
Old Oct 27, 2004 | 06:12 PM
94civicEX's Avatar
94civicEX
I got worms.
I just don't like the idea of pressing it in more than once h:.
99 Integra GSR
06 TSX
Old Oct 27, 2004 | 10:38 PM
Nelson's Avatar
Nelson
Administrator
How are your axles? Did you ever change those?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
