integra rims
Old Oct 11, 2004 | 03:49 PM
noteful's Avatar
noteful
Default integra rims
would 18" rims fit on a 99 gsr integra? what are the biggest size rims that they could fit? thanks.
Old Oct 11, 2004 | 04:19 PM
teg92's Avatar
teg92
WHAT OK YEAH!
They will but, why would you want to put 18's on a GSR
Old Oct 11, 2004 | 04:30 PM
Robstunner's Avatar
Robstunner
y0! Vito!
too big for comfort, most of the guys here will vote against 18's. but hey, its your car bro.
Old Oct 11, 2004 | 05:12 PM
CA VTEC Sol's Avatar
CA VTEC Sol
16's is the biggest i would go, 17's and you're off-roading
Old Oct 11, 2004 | 05:19 PM
randomtask77's Avatar
randomtask77
Wanderer
If you do plan on getting a set of 18's for your teggy, you would want an 18x7" wheel, with at least a +42mm offset with a 4x100 bolt pattern.
For tires, you'll want to get 215/35/18 tires.
Lastly, I'd check if your suspension is up to par, (if you have coilovers, even better) and make sure your alignment is up to spec and you should be okay.
Old Oct 11, 2004 | 06:16 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I have 17's on my ride and that is about as big as you can go and still maintain an agressive look. The bigger the wheel, the more inertia it takes to get going. My wheels weigh 15.5lbs each and weigh as much as the 16's I use to have. If you go 18 get ready to rub, even if the offset and wheel size is dead on, it's gonna tuck right under your fenders and when you hit a bump your gonna know it and it will begin to bug the shit out of you.
Old Oct 11, 2004 | 09:34 PM
FSTred912's Avatar
FSTred912
i have had 15s and 17s and i think the 17 look just big enough, but now im riding on stock tires, cause winter is coming.
