Compression test results: plz help...
Old Oct 1, 2004 | 12:25 PM
burgan_30's Avatar
burgan_30
Default Compression test results: plz help...
I had a garage mechanic do a compression test and he said that all four pistons were all "essentially" at 125 psi.
the communication between us wasn't great but i asked him that I expected it to be around 200 psi. he said 200 psi would only be for diesals.
i have since done some web searching and found out that he might have been doing a "Running compression test" where each cylinder is done 1 at a time with the car idling. I have read that these numbers are typically 1/2 that of the static tests that nearly everyone does here on this forum: this would put the numbers in the ball park of what would be expected.
is anyone familiar with a "Running compression test"?
thanks in advance,
jeff
Old Oct 1, 2004 | 12:55 PM
JimBlake's Avatar
JimBlake
I've heard about it, but I've never done it.
Another possible explanation... He took out one spark plug at a time, putting it back in before doing the next. That way the starter spins more slowly & the results are lower.
You really are only supposed to compare the pressures against each other. Because even a gauge that has a larger internal volume can make the pressures lower.
Old Oct 1, 2004 | 04:22 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
200 psi is the correct compression pressure for a GSR motor.
Go to www.c-speedracing.com in the how to section. It shows the correct procedure for a compression test. If you have a guage, it is really easy to do yourself.
BTW, your mechanic is a dumbass.
Old Oct 1, 2004 | 05:56 PM
Tobra's Avatar
Tobra
exactly
Old Oct 2, 2004 | 09:09 AM
Civic2Scooby's Avatar
Civic2Scooby
:werd: and :werd:
Old Oct 2, 2004 | 12:14 PM
newgsrdriver's Avatar
newgsrdriver
Yep...dumbass.
Did he do the test while the motor was cold? That will alter the numbers as well.
Old Oct 4, 2004 | 06:40 AM
burgan_30's Avatar
burgan_30
i just moved into town and so i wouldn't want him to be called "my mechanic".
the motor was not cold.
needless to say i won't be going back there and am going to pick up a compression tester.
jeff
Old Oct 4, 2004 | 07:47 AM
JimBlake's Avatar
JimBlake
Originally Posted by burgan_30
... going to pick up a compression tester.
Engine warmed up, pull all 4 spark plugs.
Pull ECU fuse to disable fuel injection & spark.
Hold the gas pedal floored.
Either crank the same # of revolutions (7?) for all 4, or crank as long as it takes for the pressure to quit increasing.
