Type R TB
Old Sep 29, 2004 | 10:51 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default Type R TB
Will a throttle body off a 99 Type R fit a 95 GSR?? If so, would it make much of a difference?
Old Oct 5, 2004 | 04:59 PM
teg92's Avatar
teg92
WHAT OK YEAH!
Ya there both B series Im sure it will work
Old Oct 6, 2004 | 08:01 AM
IN VTEC's Avatar
IN VTEC
The OD of the ITR throttle body is slightly larger than the other B-series throttle bodies.
You might need a different intake coupler if you have an aftermarket intake or you can use an original ITR intake pipe.
If you have an OBD-1 Integra, then you should get a JDM ITR throttle body with the EVAP purge port. If you have an OBD-2 Integra, then you should get a USDM ITR throttle body.
Throttle response is slightly better, but I'm not sure about the increases in WOT power.
