Loose Steering Wheel?
Old Sep 27, 2004 | 02:29 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default Loose Steering Wheel?
On my 95 GSR, the steering wheel seems to be loose. If you hold it at 3 oclock and 9 oclock, you can move it up and down. It feels like the nuts or screws have started backing out. Has anyone else ran into this issue???
Old Sep 27, 2004 | 02:52 PM
CA VTEC Sol's Avatar
CA VTEC Sol
check the steering column lever, make sure it's up and tightened all the way
Old Sep 27, 2004 | 02:56 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
You dont understand. Its not the column that is moving, it's the the wheel. Thanks for the imput.
Old Sep 28, 2004 | 09:48 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Please help!! If anyone has a diagram of the the wheel or column that would be great! Thanks!
Old Sep 28, 2004 | 10:06 AM
ISP James's Avatar
ISP James
DAMIMRED
the plastic where your knees off comes out then you should see 2 bolts that hold the column in place, you can try tightening these down.
if you're sure its the wheel, you're gonna have to take out the airbag.... disconnect the power from the battery then there is a plastic piece under the airbag, take that off. under that there is a clip (yellow or red cant remember which) unplug that, thats your airbag power supply... remove the airbag and tighten the nut down.
but i have no idea how that nut could have possibly come loose.
