Light clutch
Old Sep 24, 2004 | 04:38 PM
redteg's Avatar
redteg
Default Light clutch
I have a 94 integra ls w/ 107k and the clutch pedal is really light (have not had the car for that long). Also, the shifter feels really notchy and sometimes has trouble getting into gear w/o double clutching. I just got a new clutch master cylinder and bled it so i know its not that. Under hard accceleration, I have to really feather the clutch during the 1-2 shift to keep the car from rocking. Is it the clutch?
Thanks
Old Sep 25, 2004 | 02:45 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sorry to tell you, but it sounds like a new clutch is in your immediate future.
Old Sep 25, 2004 | 07:22 PM
honura's Avatar
honura
Seni
Yep new clutch is needed.
Old Sep 25, 2004 | 08:39 PM
acuragal03's Avatar
acuragal03
not necessarily true...mine does this too and i have a new clutch. i was told to check my tranny fluid, i did and it was almost empty. i drained and filled it, and its still doing the same thing.
Old Sep 27, 2004 | 06:55 AM
redteg's Avatar
redteg
Thanks
Old Sep 27, 2004 | 11:28 AM
m735is's Avatar
m735is
When I changed to an aftermarket slave cylinder my clutch became very light. I bleed it and that didn't help. I did notice that the actuation rod that came with the aftermarket one was shorter than the stock one (the rod that sticks out of the slave and presses on the relaese fork). I did replace the clutch with an aftermarket at the same time, maybe the pressure plate isn't as strong as the the stock one was?? I have no shifting problems though.
Old Sep 27, 2004 | 12:03 PM
LT's Avatar
LT
The deer had to die!
yea, my pedal is REALLY light, but i don't have any shifting problems.
Old Sep 27, 2004 | 05:10 PM
redteg's Avatar
redteg
Under hard acceleration it doesn't grab firmly and I definitely can't chirp the tires in 2nd because if you don't feather it near the engagement point, it rocks. The clutch master is honda oem along w/ the fluid. I guess the clutch needs to go. Thanks
