Noisy Injectors
Old Sep 13, 2004 | 02:26 AM
94tegracer's Avatar
94tegracer
Default Noisy Injectors
i just did a LS vtec head swap on my stock LS and the injector are make a load clickin soun. i am sure it is the injector for sure cuz i had a valve adjustment done and used a stethoscope (dont know if spelling is right) to pin point the sound. also used the injector off my LS head (i got injectors with my GSR head) and still have the same sound. please help
Old Sep 13, 2004 | 03:09 PM
j87w's Avatar
j87w
One of my friends had the problem on his prelude. If I recall correctly it was a sign the injectors were going to fail. Im not sure on that but just thought I would tell you.
Old Sep 13, 2004 | 06:16 PM
cartuner's Avatar
cartuner
It's not the Injectors. I would have to say it's the lost motion assemblies. Same problem with my friends car. We thought it was the injectors too, he bought new injectors and same problem. Months later we did the headgasket and I decide to inspect the rocker arms. I notice that the mid rocker arm sat lower than the ones on my head. I took out the lost mostion asmebly and measured the height, sure enough it was less than stock specs, bought new ones and problem solved.
Old Sep 14, 2004 | 07:38 PM
94tegracer's Avatar
94tegracer
its is not the lost motion assy. cuz before i put the head on the head was dismantled and inspected with everything comin up ok
i tried different injectors and it didnt work but it is the injectors
for sure
Old Sep 14, 2004 | 08:21 PM
cartuner's Avatar
cartuner
Ok, was you're injectors doing it before the VTEC head? If it wasn't then you've just ruled out the injectors. I'd recheck your valve adjustment.
