car makes noise after converting to OBDI
Old Sep 9, 2004 | 04:41 PM
integsracer's Avatar
integsracer
Default car makes noise after converting to OBDI
i have a 1996 GSR and i converted to OBDI. now the car makes a weird hissing noise when its on. ive tried two different harnesses, and two different OBDI P72 ecus and the same noise is still there. does anyone know what it could be?
Thanks,
Jon
Old Sep 10, 2004 | 01:34 AM
Kai's Avatar
Kai
Rotorphile.
Well, let's start with the obvious: why did you convert to OBD-I? How did you do it?
That aside, an engine management conversion will not make odd noises in any case I can think of.
Old Sep 10, 2004 | 06:12 PM
integsracer
im going turbo and using hondata. hondata isnt compatible with obd2 so i had to convert.
sorry, what i meant by converting to obd1 was i just changed the ecu and used a conversion harness. the motor is still obd2 but my ecu is obd1.
thanks,
jon
Old Sep 11, 2004 | 10:53 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Check all the vacuum fittings first [IM, Intake, PCV] - if you're still naturally aspirated.
If you are already boosted then check all the potential areas for intake or exhaust leaks.
Old Sep 11, 2004 | 03:24 PM
integsracer
i can check, but the weird thing is the sound goes away when i put my obd2 ecu back in.
