fixing finish on my set of fat fives?
Old Sep 5, 2004 | 07:02 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default fixing finish on my set of fat fives?
http://tinyurl.com/57ejj
some one look at that and help me, please! does it need a new clear-coat? sanding? or what?
Old Sep 5, 2004 | 07:08 PM
honura's Avatar
honura
Seni
Dahm you need the works on that man! Your gonna need to sand and reclear coat it.
Old Sep 5, 2004 | 08:07 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
some one told me that i hafta just "re-polish" them. will that work? and can i do that myself?
Old Sep 6, 2004 | 10:05 PM
Tobra's Avatar
Tobra
Ideally, you would take tires off rims, remove all the clear coat, polish/clean them up respray clear and go from there
Old Sep 12, 2004 | 06:52 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
i sanded the whole wheel with 800 grit sand paper, then 1,000. then i repolished them. turns out the only part that really got raw was the blemish spots. so when i polished the wheel, now the wheel has really bright spots, and normal aluminum spots. the bright spots take the place of the blemishes. i think im gonna have to sand the whole thing with lower grit sandpaper, and then repolish the whole wheel.
anyone know what grit sand paper i should use to make the whole wheel raw? thanks
Old Sep 13, 2004 | 11:38 AM
Tobra's Avatar
Tobra
You need to take the clear coat off, you can do that chemically or with sanding, if you are sanding by hand, it will take a while to do.
Old Sep 13, 2004 | 12:42 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The key to a long lasting, quality finish is proper surface preparation - which is why IMO sandblasting is the best way to completely strip the surface down to bare metal.
I say sandblast and machine polish the alloys, then clearcoat them (or powdercoat if you're interested in a different color).
Old Sep 13, 2004 | 05:45 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
i think im gonna use paint stripper and take the whole clear coat off. then polish, then clear coat it.
Old Sep 14, 2004 | 02:09 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
clear coat off, sanded up to 1,000 grit.
