something is wrong!
Old Aug 27, 2004 | 08:33 PM
joebot's Avatar
joebot
Default something is wrong!
I have a 1990 integra rs, A few days ago my car started idleing really weird (cold start up idles at 3000 rpm, steadies out to 1000-2000 rpm. give it gas and it jumps between 1000-2000rpm.) I have replaced the IAC,map sensor andpcv valve. I dont have a check engine light on. i'm going to replace the coolant temp sensor tommorow. could this be a vac. leak?....can anyone help me? Joe
Old Aug 28, 2004 | 07:40 AM
honura's Avatar
honura
Seni
Could be a vac. I had the same problem. I looked around and found that one of the vaclines where cracked. (so small you could'nt see if without removing it and looking close)
Old Aug 28, 2004 | 12:47 PM
Tobra's Avatar
Tobra
You should probably check out all your underhood rubber, vac lines, water hoses etc. Maybe just replace all of it so you don't get any surprises
