Biggest tires on stock blades?
Old Jun 24, 2004 | 10:17 PM
dapel's Avatar
dapel
Default Biggest tires on stock blades?
So then I want to know what are the biggest/widest tires that I can fit on stock 00-01 GSR blades? And just in case you forgot, stock size is 195/55/15. Thanks.
-Dan
Old Jun 25, 2004 | 12:05 AM
GSR4444's Avatar
GSR4444
6 inch lift with 265/75/15's outta fit.
what do u mean? the largest size/width while keeping stock diameter?
or largest size without rubbing?
Old Jun 25, 2004 | 03:18 AM
BONE's Avatar
BONE
I would stick with 205-50-15 that is pretty close to the stock specs and they look good with a slight bulge to give you some rim protection also.
Old Jun 25, 2004 | 06:55 AM
b00gers's Avatar
b00gers
the stock blades are 6.5 inches right? maybe you can try 205 azenis. they are made wider than most 205 tires.
Old Jun 25, 2004 | 09:22 AM
teg_fan's Avatar
teg_fan
I like integra's
I think blades are 6 inches wide, no?
Old Jun 25, 2004 | 05:16 PM
dapel's Avatar
dapel
Yeah I'd like to get the Azenis to fit if I could. Damn good ass tires...... 205/50/15 it is then......... THanks.
-Dan
Old Jun 26, 2004 | 09:06 AM
dapel's Avatar
dapel
Holy crap Yoko makes Ao32rs in that size as well....... i'd get those again if I had to go that route again..............
Old Jun 26, 2004 | 12:25 PM
LT's Avatar
LT
The deer had to die!
stock alloys are 6" wide
widest tire is 205 (recommend 205/50-15)
Old Jun 26, 2004 | 01:23 PM
randomtask77's Avatar
randomtask77
Wanderer
:werd:
Old Jun 27, 2004 | 02:29 AM
Spec R's Avatar
Spec R
Bridgestone Potenza S-03 Pole Position in 205/50/15 is my recommendation. Who cares if they're expensive. They're the only part of your car that's supposed to be in contact with the road.
DB Squad
Integra Forum Moderator
