need help with my ac... stopped working ... please help
can anyone please help?? i got a 1995 acura integra gsr
my air conditioning (ac) used to work, then i hit a deer and messed up my front end... i got that taken care of but my ac stopped working i dont know why all the relays are fine... the electricity is right... but it just doesnt turn on...i dont know why the relay doesnt turn on... but it works because i tried it test it... is there some kind of sensor that needs to be plugged in? i dont know what to do or if anyone knows were to find the air conditioning wiring diagram that would be very helpful... thanx -vova104- |
There should be an AC wiring diagram in a repair manual. The Helm book is best, but Chiltons & Haynes ought to have it too.
But if you hit a deer, I'm guessing your condenser or a refrigerant line started leaking. There's a pressure switch, if your refrigerant leaks out it won't let your compressor run. |
Check your ac lines, behind your left headlight, and make sure they are ok. Also check the hoses and fittings behind the radiator. You could have maybe messed up your compressor too
