Dyno Tune Question
Old Mar 31, 2004 | 01:21 PM
pbizzlegsr's Avatar
pbizzlegsr
Default Dyno Tune Question
i plan to get my car dyno tuned really soon but am not sure if i should get a fuel pressure regulator or not..currently im i have a vafc and skunk cam gears..those being tuning tools..the thing is im told that i would need a fpr to lean or richen and vafc to do the other i forgot which for which..would i be okay with just a vafc..i want to get the best out of the tuning but my situation is im in ca and with either b&m fpr and gauge or aem fpr..id fail visual for sure..any input suggestions thanks
Old Mar 31, 2004 | 01:29 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
No point messing with the actual fuel system parts unless you're changing out injectors that will need a new pump. If you have the stock pump and injectors, keep the rest of the stuff stock.
Old Mar 31, 2004 | 01:32 PM
pbizzlegsr's Avatar
pbizzlegsr
ok because i was told its better the more tuning tools the tuner gets to use..i was told by many that vafc isnt efficient in doing either leaning or richen fuel so id need the fpr to do that other task so thats why i ask
Old Mar 31, 2004 | 01:50 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The whole point of the VAFC is to adjust the mixture. You don't need to play with fuel pressure for it to be effective.
Old Mar 31, 2004 | 01:54 PM
pbizzlegsr's Avatar
pbizzlegsr
ok i know the exact point of it now..fpr to richen and vafc to lean ..to get the most efficient output from tuning..but your sayin ill be fine wit jus the vafc for tuning?
Old Mar 31, 2004 | 07:38 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The VAFC is perfectly capable of adjusting the a/f ratio in both directions, through changes to injector duty cycle. You don't need to touch the fuel pressure.
Old Mar 31, 2004 | 09:06 PM
Padawan's Avatar
Padawan
Future Jedi
There is a severe limit to the amount of fuel that can be added with a piggy-back such as a V-AFC or an Field unit, especially in the upper RPM ranges when the MAP signal is approaching its max value (leaving very little or no room for manipulation via the piggy-back). Most tuners (including one of the most capable on the east coast, employ the method of raising fuel pressure (and thus adding fuel) with an adjustable FPR, then leaning out where necessary using the piggy-back.
Old Apr 1, 2004 | 07:18 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Right, assuming of course that this motor is actually modified to the point where it needs more fuel in the upper rpm range. The stock ECU program is generally already very rich in that area, and unless he's got some cams (which haven't been mentioned) I see no use for an FPR.
Old Apr 1, 2004 | 11:05 AM
pbizzlegsr's Avatar
pbizzlegsr
i forgot to mention i would have itr cams in by by the time of the dyno tune
pbizzlegsr
10
Mar 16, 2004 08:11 AM
pbizzlegsr
4
Dec 3, 2003 09:16 PM
Dru01
10
Mar 23, 2003 09:46 PM
LilWhiteCoupe
92+ Civic/EL & Del Sol
2
Oct 10, 2002 03:00 AM
slow_civic
Sep 15, 2002 08:49 PM
