Control Arm
Old Mar 29, 2004 | 08:27 AM
Madtekniques's Avatar
Madtekniques
cryoteknical
Default Control Arm
I need to replace my right front upper control arm. Is there anything that I should know if I am going to install this myself?
ps I will be getting an alignment afterwards.
Old Mar 29, 2004 | 08:49 AM
LT's Avatar
LT
The deer had to die!
its pretty straight-forward, remove the bolts, remove the arm, replace, reinstall everything.
Old Mar 29, 2004 | 09:13 AM
Asahi's Avatar
Asahi
Administrator
You have to pull the shock. Don't waste time fighting it, trying not to. At least I did and it is way easier that way.
Old Mar 29, 2004 | 09:47 AM
sekongen's Avatar
sekongen
Also if you have a camber kit dont forget to swap that out too
Old Mar 29, 2004 | 10:22 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
These should help you out.
https://www.honda-acura.net/forums/s...d.php?t=127775
https://www.honda-acura.net/forums/s...d.php?t=127432
Old Mar 29, 2004 | 03:02 PM
Madtekniques
cryoteknical
The first link is excellent thank you!
Just to confirm though, I don't have to worry about the springs right? As in I don't need a compressor to hold them or anything, the control arm is independent of that?
Also, I'm seeing bushings there, do I need to purchase new bushings or will they come with the new control arm? I am going to be buying it from the dealership if that helps.
Old Mar 29, 2004 | 05:58 PM
westcoaststyle
Ya, you don't have to remove the struts/springs.
Glad I could help.
Old Mar 29, 2004 | 06:21 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
They should come with new bushings, but even if they don't, they're not too expensive. I work at a body shop and I've had to remove a few control arms. Not too bad. Good luck with it.
Old Mar 29, 2004 | 09:57 PM
Madtekniques
cryoteknical
Wonderful, thanks once again. I'm going to give it a go this weekend and hopefully none of the bolts are seized, I've got my fingers crossed.
98teggy
11
Jan 29, 2004 06:00 PM
A_D
Accord
Aug 8, 2003 08:57 PM
accord_vti
Accord
6
Jul 29, 2002 12:49 PM
born2speed
4
Jul 21, 2002 06:50 AM
