Suspention decision
Old Feb 24, 2004 | 11:05 AM
typer rick's Avatar
typer rick
Which one would you guys think is the best setup, KYB AGX high performance shocks with ground control coilovers, are Koni yellow adjustable shocks with ground control.
Old Feb 24, 2004 | 11:06 AM
Tony
Guest
Posts: n/a
What you using the car for? If nothing more than a daily driver with some occassional track use, don't mess with the OEM ITR suspension. It's very very good as is.
Old Feb 24, 2004 | 11:08 AM
typer rick's Avatar
typer rick
Using the car for everyday use and drag racing.
Old Feb 29, 2004 | 09:36 AM
grrlie's Avatar
grrlie
Konis are the shock of choice in this household (on every car we own)....and the choice for most of the Honda/Acura people we know....we road race though (but do use on daily drivers as well as track car), with Carrera coil-over hardware...
Old Mar 9, 2004 | 10:58 AM
Chris N
Guest
Posts: n/a
Konis and Ground Controls would be a good choice.
Just beware that on stock valved OTS Konis, if you go above 350lb springs, the ride quality is going to be terrible. This is what happens when your suspension is oversprung.
My roommate had OTS, stock valved Konis and 400lb Front/500lb Rear springs - the ride was absolute crap. VERY rough, bouncy, jarring.... just bad. If you plan to run rates above 350lbs, it would be wise to look into an entry level coilover or re-valved dampers.
But with 'street' rates - the Koni/GC setup would be good for your application.
