Final Drive
Old Feb 22, 2004 | 08:11 PM
AlvinOne7's Avatar
AlvinOne7
What exactly does a final drive do for our car?
Old Feb 23, 2004 | 05:24 AM
Tony
Guest
Posts: n/a
Globally shortens the gearing and improves acceleration.
Old Feb 23, 2004 | 10:42 AM
AlvinOne7's Avatar
AlvinOne7
I heard that it puts a sixth gear in. is that true.
Old Feb 23, 2004 | 11:46 AM
Tony
Guest
Posts: n/a
Please tell me this is a joke.
Old Feb 23, 2004 | 12:19 PM
swtxaznrac3r's Avatar
swtxaznrac3r
i'll say nothing to be nice
Old Feb 23, 2004 | 01:46 PM
Champ R's Avatar
Champ R
I nominate this guy for n00b of the year award.
Old Feb 23, 2004 | 04:36 PM
George Knighton
Guest
Posts: n/a
Don't listen to them. Listen to us.
The confusion among the uninitiated could stem from the fact that there is a gear included in many JDM axle kits.
However, that is an alternate first gear, not a sixth gear.
Some people will also switch the fifth gear to lower RPM on the highway. Most of us in here, however, would not do that, since it negates some of the effect of installing the JDM final drive in the first place.
Hope that helps a bit.
Old Feb 24, 2004 | 06:21 PM
nsxtasy
Guest
Posts: n/a
Yes, it globally shortens the gearing. There is better acceleration with a shorter FD, but only as long as you are in the same gear with each setup. Here's why.
Acceleration is a function of torque at the wheels, which is torque at the crank times gearing (less drivetrain losses). Most of our cars have a relatively flat torque curve, so where you are in the revband doesn't matter as much as how much gearing you have. In a nutshell - if you have shorter overall gearing, you have faster acceleration. So your point is correct, that shorter gearing means that the car accelerates faster... as long as you can remain in the same gear. However, as soon as the shorter gearing forces you to upshift, you are at a disadvantage because your overall gearing is actually longer.
For example, let's use the ITR as an example, with stock size (195/55-15) tires, taking deflection into account, assume we will accelerate to the 8400 RPM stock redline, and compare the stock gears with the stock FD (4.4) vs the ATS FD (4.928). We can calculate the total gearing (ratios of each of the regular five-speed gears times the ratio of the FD) at various road speeds. This will tell us which FD gives better acceleration, as follows:
0-35.6 mph: Stock FD first gear total gearing 14.21, ATS FD first gear total gearing 15.92, ATS is quicker (12 percent gearing advantage)
35.6-39.9 mph: Stock FD first gear total gearing 14.21, ATS FD second gear total gearing 10.37, Stock is quicker (37 percent gearing advantage)
39.9-54.7 mph: Stock FD second gear total gearing 9.26, ATS FD second gear total gearing 10.37, ATS is quicker (12 percent gearing advantage)
54.7-61.2 mph: Stock FD second gear total gearing 9.26, ATS FD third gear total gearing 7.19, Stock is quicker (29 percent gearing advantage)
61.2-78.9 mph: Stock FD third gear total gearing 6.42, ATS FD third gear total gearing 7.19, ATS is quicker (12 percent gearing advantage)
78.9-88.4 mph: Stock FD third gear total gearing 6.42, ATS FD fourth gear total gearing 5.46, Stock is quicker (18 percent gearing advantage)
88.4-104.0 mph: Stock FD fourth gear total gearing 4.87, ATS FD fourth gear total gearing 5.46, ATS is quicker (12 percent gearing advantage)
104.0-116.5 mph: Stock FD fourth gear total gearing 4.87, ATS FD fifth gear total gearing 4.18, Stock is quicker (17 percent gearing advantage)
116.5-135.7 mph: Stock FD fifth gear total gearing 3.73, ATS FD fifth gear total gearing 4.18, ATS is quicker (12 percent gearing advantage)
135.7-152.0 mph: Stock FD fifth gear total gearing 3.73, ATS FD exceeds redline, Stock is quicker
As you can see, when both FD ratios put you in the same gear with either setup, the shorter FD is faster. But at speeds where the shorter FD puts you into a higher gear, the stock FD is faster - considerably faster.
This is why the stock FD can be a big advantage on tracks where you spend a lot of time near redline, but the shorter FD can be a big advantage on tracks where you don't. So theoretically, if you were on a track where you spent the entire track driving between 79 and 88 mph, or between 88 and 104 mph, you would have a clear cut winner between the two gearing setups. However, most tracks have enough of a mix of speeds that you're probably going to be spending some time in the same gear, and some time in the higher gear, and the gains in one set of stretches will largely offset the losses in others.
On a dragstrip, OTOH, the shorter FD is more consistently an advantage, because of the large amount of time you would be in first gear, and in second gear, with either setup. In our ITR example, from 0 to 55 mph, the shorter FD is a significant advantage most of the time; however, above 55 mph (where you spend road course time) the advantage swaps back and forth between the two setups, depending on the road speed.
That's a long answer to a short question, I know...
Old Feb 25, 2004 | 08:50 AM
Tony
Guest
Posts: n/a
Originally Posted by nsxtasy
A whole bunch of stuff posted by nsxtasy
In theory I know what you posted, but opted to go for the short answer because it is the easiest way to explain in laymans terms what a shorter FD does.
There is NO way I could have communicated that gearing information as detailed or as completely as you did. Great job. I'm sure others will appreciate it as much as I did.
Old Feb 25, 2004 | 03:55 PM
Bowdwn's Avatar
Bowdwn
tks for info....learn some new every day.... 8)
