Any suggestions on reducing oversteer?
Old Jun 29, 2003 | 04:05 PM
kabob's Avatar
kabob
Every AutoX it seems like my rear end is more loose than a French whore in Paris when the Nazis rolled through. I'd rather not mess with my sway bars but if that's what it takes, I might consider it. On race day I run with Euro ITR Enkeis with 205/50/15 Falken Azenis.. would tire pressure adjustments help out enough?
Old Jun 29, 2003 | 07:01 PM
BLKITR's Avatar
BLKITR
ROFLMAO
Hey Kabob, I don't have an answer for you, but when I read that line I about lost it. That was too funny. :lol:
Old Jun 30, 2003 | 06:39 AM
sscguy's Avatar
sscguy
What tire pressures are you running when you autox?
Old Jun 30, 2003 | 11:33 AM
kabob's Avatar
kabob
Well, in the past I've run 40 psi front and 38 in the back but more probably due to my utter lack of skills, the car was drifting sideways around turns. Last week, I just left the pressure alone after they'd been sitting on my balcony for about a month and the grip was fine but the oversteer more than a little squirrely. Dorky me only checked the front tires at the time and they were at 33 psi.
I 'spose I could just improve what I laughably call my version of performance driving :lol:
Old Jun 30, 2003 | 12:05 PM
Dave-ROR
Guest
Posts: n/a
step on the gas pedal
Old Jun 30, 2003 | 12:15 PM
Chris N
Guest
Posts: n/a
If you want less oversteer, get on the gas and take air out of the rear tires if you are really loose like that french whore you so eloquently described. =)
You are supposed to flat foot every autox course anyways!! :P
Old Jun 30, 2003 | 12:48 PM
TypeR 801's Avatar
TypeR 801
It's almost unimaginable to me that you could have too much oversteer autocrossing. In stock form on Azenis I can hardly get the car to rotate. Even the modded cars with significantly higher spring rates in rear + Mugen rear sway bars don't swap ends on pressures like yours. They actually take camber out of the rear (from lowering) to get the car to turn more.
It might be worth asking what your suspension set up is? Shocks, spring rates, sway bars how much camber you're running...etc. That may help answer this question.
Originally Posted by Chris N
[quote:e641cfa1b8="dawhiteboy"]step on the gas pedal
You are supposed to flat foot every autox course anyways!! :P[/quote:e641cfa1b8]
Old Jun 30, 2003 | 01:23 PM
kabob's Avatar
kabob
Maybe it's a matter of too much gravel on the course as well.. I'm on stock suspension, btw. I won't be changing a thing until stuff starts breaking or next AutoX season, whichever comes first.
I'm learning to keep on the gas 90% of the time on the course but I still stay off on the hairpin turns since I haven't perfected left-foot braking, yet. I'm left-footed so it's an excercise in VERY abrupt stops right now ops:
I dunno about difficult to rotate. I've completely spun the car twice on the Azenis and finally learned to stomp on the gas and pull the car through a sweet 4-wheel drift the last time I lost the rear end
Old Jun 30, 2003 | 02:48 PM
Chris N
Guest
Posts: n/a
I dunno, but I have the stock suspension + 23mm rear sway, and when i pump up the rear tire pressures on my azenis, holy wow. Crazy oversteer when I lift.
At the track, I run almost 10 less psi than the fronts to make the oversteer more 'on demand' than unmanagable. At autox, I run 40/39 or 40/40 with decent success.
Old Jun 30, 2003 | 05:55 PM
kabob's Avatar
kabob
Now you have me confused.. you say you're running 10psi less than in the front but then you say you run 40/40. Which is it?
-- Perplexed in TX
