Integra chassis question...
Old Jan 30, 2003 | 11:30 PM
The Gnome's Avatar
The Gnome
Are there any chassis differences between the LS/GS, GS-R, and Type R? I know that the Type R chassis is specially designed specifically for that car, but will suspension components built for a Type R be able to be used on a LS model?
I'm helping a friend with her LS model Integra, and we're looking for a good coilover/suspension setup. I suggested the Tein type Flex setup, but it looks like it's only applicable to the Type R. Would it work on the LS anyway? It's a 1996 if that helps any.
Thanks in advance.
Old Jan 31, 2003 | 04:00 AM
Trey
Guest
Posts: n/a
Thanks in advance.
Everything will bolt up but with respect to suspentoin the LS will need Type-R Rear lower control arms to work with Type-R suspension.
Old Jan 31, 2003 | 10:13 AM
The Gnome's Avatar
The Gnome
[quote:1d839ab3de]Everything will bolt up but with respect to suspentoin the LS will need Type-R Rear lower control arms to work with Type-R suspension.
[/quote:1d839ab3de]
so the control arms on the front are the same?
Thanks for the help.
Old Jan 31, 2003 | 11:21 AM
Trey
Guest
Posts: n/a
[quote:e8b9dce6b0]Everything will bolt up but with respect to suspentoin the LS will need Type-R Rear lower control arms to work with Type-R suspension.
Thanks for the help. [/quote:e8b9dce6b0]
Front are the same, rear are different
Old Feb 10, 2003 | 05:09 AM
Type R 98's Avatar
Type R 98
You need a Type R cross-member in the back for a type R suspension to fit.
Old Feb 10, 2003 | 07:02 AM
Trey
Guest
Posts: n/a
No you don't.
All you need are the Type-R Rear lower control arms. Trust me, done it more than once.
The rear swayber is a different story but a little costom fabrication will make that work.
Old Feb 10, 2003 | 01:56 PM
Type R 98's Avatar
Type R 98
well correct me if im wrong but the rear control arms connect to the cross member that the GS-R doesn't have and is exclusive to the Type R.
Old Feb 10, 2003 | 04:45 PM
Trey
Guest
Posts: n/a
They do connect to the crossmember that the GSR doesn't have. BUT the mounting location on both the GSR subframe and the Type-R Subframe are the same for the rear LCA's. THe only difference in subframes in the Swyabar mounting points.
Old Feb 11, 2003 | 11:49 AM
Type R 98's Avatar
Type R 98
fair enough, lets call it a draw, ahah
