Please help!!!!!......just installed AEM CAI.....whistling
i just installed an AEM CAI in my 00 ITR. When i have the gas pedal half the way down i hear a whistling noise....it has to be from the intake...im almost positive. I have already checked everything several times and everything seems to be installed correctly. Does this happen to anyone else..do you think i have something wrong with the intake i recieved from AEM....any ideas or solutions would be greatly appreciated. This damn whistling is annoying the hell out of me!!!!
My friend is a certified acura mechanic, actually one of the few certified on the nsx. He got to talk to an engineer about that, and they said it is common. some do it, then some dont. It is air leaking through the throttle body gasket. No big deal because it is just extra air trying to find a place to go. That is why you hear it more when allowing more air flow.
Guest
Posts: n/a
"It is air leaking through the throttle body gasket. "
Not on my car, I changed the gasket and sealed that sucker up very well. I am sure its the air spinning inside at a high rate of speed that does it, Kinda like a tornado (not that bs thing you add either).
I've acutally taken my TB off without replacing that gasket, and it still doesn't leak.
Tell your buddy to go slap the engineer(JK)
Later!
Aj
