Floor jack position
Old Oct 5, 2002 | 11:08 PM
TypeRPaul's Avatar
TypeRPaul
I was just wondering if there is a good place to put a floor jack up on a 01 itr and where it would be...i know where to jack up with the reg jack in the car.....but then where to put the jack stans....any help would be appreciated...thanks
Old Oct 6, 2002 | 08:32 AM
bbasso
Guest
Posts: n/a
If you use the tow loop in the rear you will be fine. It can handle the weight and will lift both rear tires. Just be sure to use jack stands to support the weight.
Old Oct 6, 2002 | 01:13 PM
Trey
Guest
Posts: n/a
You can also find a jack point in the front of the car just under the radiator support. It will be just past the plaustic undertray and be in a cutout area.
Old Oct 6, 2002 | 08:37 PM
Aj's Avatar
Aj
You can also use the tow hooks in front even though you can;t se them unless the car is jacked up, they are easily accesable when the car is in the air, and are pretty out of the way. Either that or you can use any where on the subframe, or regular parts of the frame.
Good Luck...
Aj
Old Oct 7, 2002 | 08:15 AM
bbqman's Avatar
bbqman
Btw, with the chassis so rigid, you can also jack the car up using the front rocker panel point.
This raises the car with both wheels at the same time.Useful when swapping wheels or when the car is too low for the before mentioned front rad mount point and rear tow hook point.
