Seat Removal
Old Sep 26, 2002 | 04:46 PM
Napolean Solo's Avatar
Napolean Solo
has anyone removed their rear seats? and how hard is it to do?
seems like they could weigh about 30lbs. and weight saving is definately good.
Old Sep 26, 2002 | 07:17 PM
bbasso
Guest
Posts: n/a
actually very easy. the uppers , fold them and look at the sides and remove the black "C" clip with a pliar then pull out.
As for the bottom, If I remeber just pull hard from the leading edge and your done.
I could be wrong but I think I'm right.
As for the weight- to me its not worth the 25-30lbs, I would rather it look like a car then a race car.
Old Sep 26, 2002 | 08:16 PM
Trey
Guest
Posts: n/a
I think we weighed the rear upper and lower seats to be more like 10 lbs. Lower seat weighs nothing.
Old Sep 26, 2002 | 09:12 PM
Napolean Solo
sounds good to me, i have a 90 CR-X too and for some reason i like the feeling of having a two seater, it feels more sporty rather than "family-functional." thanks
Old Sep 27, 2002 | 05:41 AM
Trey
Guest
Posts: n/a
Meant to say it is easy to do. 2 clips and done in 5-7 minutes.
Old Sep 27, 2002 | 08:01 AM
itr449's Avatar
itr449
the bottom doesn't just pull up and out there is a hook with a bolt in it that you have to remove after you take the back out. i do agree that is very simple and can be don in 5-10 minutes
Old Sep 27, 2002 | 09:18 AM
Trey
Guest
Posts: n/a
oops forgot. 10mm bolt. Still under 10 min.
Thanks
Old Sep 30, 2002 | 12:01 PM
Aj's Avatar
Aj
:?: Does anyone know if you can remove the bottom section before removing the backs of the seats, I was planning on putting in a new fuel pump, and the last time I did it was on our race car which has no interior at all. Ordinarily I wouldn't mind taking out the back seats, other then the fact that I have my amps and EQ mounted to them, so it would be a real pain in the ass. Thanks guys. :?:
Aj
Old Sep 30, 2002 | 12:05 PM
Trey
Guest
Posts: n/a
my first instinct is to say no. It would definitely be more difficult. YOu can pop the 2 clips and pull the seats out of the pivots and just slide them back slightly without disrupting amps or wiring. then easily get to the one bolt for the lower seat.
Old Sep 30, 2002 | 04:02 PM
Aj's Avatar
Aj
I think that's what I will try, Thanx dude.
Aj
