CV shaft... does it split?
Old Mar 25, 2004 | 10:53 AM
91integrals's Avatar
91integrals
u r teh sux!!1!111!
Default CV shaft... does it split?
The main half shaft that runs from the drivers side of the transmission and has the carrier bearing splits right? it splits after the carrier bearing...
If it is supposed to split, but it wont, what is causing it not too, and how can i get it to split?
this is the last thing holding me up with the alternator changing job i am doing, and its really frustrating.
Old Mar 25, 2004 | 11:28 AM
Daniel's Avatar
Daniel
If you are asking if the intermediate shaft and axle can seperate, then that is correct. You'll need to first remove the axle from the driver-side hub and then pry it out of the intermediate shaft with a lot of leverage and a pry-bar.
Old Mar 25, 2004 | 05:35 PM
91integrals
u r teh sux!!1!111!
Thats what i thought.. Hmm, last time i did it it just fell out.
Old Mar 25, 2004 | 06:09 PM
LT's Avatar
LT
The deer had to die!
yes it splits...but for god's sake, do not pull on the axle from the hub!!!! you'll pull the carrier bearing apart. I've pulled my axles many times and have done it before. you'll have to pull from the point where the axle exits the intermediate shaft.
Old Aug 29, 2004 | 05:28 PM
Big Red's Avatar
Big Red
OH NO. Now I read this.
I tried and tried to get the left axle out. Including pulling on the hub end. I could not get anything out. The other axle I got out.
I finally took the axle support brace loose from engine and the whole axle came out. Got the clutch changed and putting everything back.
Now when I go to reconnect the hub, the axle seems about 2" too long. I think I messed up the carrier bearing. I can pull out on the shaft/axle and turn it 1/4 turn and it will go back in. But it doesn't go in any further.
I've got two questions. First, does the axle actually seperate into two pieces? Second, if I seperated the carrier bearing, how can I get it back together?
KingPin
Jun 1, 2003 10:12 AM
Import-Tooner
Engine Swaps, Tech & Tuning
May 7, 2003 08:00 PM
ChrisGSR
2
Mar 20, 2003 12:46 PM
pringle
Accord
2
Feb 9, 2003 01:32 PM
Gray EG
Jan 20, 2003 06:59 AM
