p30 on my gsr??
Old Dec 18, 2003 | 04:11 AM
NOSon's Avatar
NOSon
Default p30 on my gsr??
My GSR came with a p30 ecu instead of a p72. Are they the same? Im still a complete noobie btw.
Old Dec 18, 2003 | 08:36 AM
Snoopy's Avatar
Snoopy
been there done that
a P30 came from the 92-95 del sol vtec which has a b16. very different from a p72
Old Dec 18, 2003 | 11:08 AM
airon's Avatar
airon
AARONNOJIMA.COM
what year gsr do you have?
you dont happen to have a 92-93 do you?
Old Dec 18, 2003 | 12:15 PM
NOSon's Avatar
NOSon
i have a 95 gsr. having a p30 instead of a p72, what does that tell me??
Old Dec 18, 2003 | 02:14 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The P30 was originally intended to run the B16A motor. So, you *might* have a B16A instead of a B18C. You can check the block code to see what motor it is, it's kind of down and to the left as you're facing it, near where it bolts to the bellhousing of the transmission.
As long as you still have a B18C1 then it's really not a big deal, the P30 can run the B18C1 just fine.
Old Dec 18, 2003 | 02:19 PM
NOSon's Avatar
NOSon
my motor is a b18c1. what's the redline on the p30?
Old Dec 18, 2003 | 08:51 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
ECUs don't have red lines, tachs do. ECUs do however have rev limiters and I believe both the P30 and P72 have their limiters set to 8400 rpm.
Old Dec 18, 2003 | 11:16 PM
Kai's Avatar
Kai
Rotorphile.
92-93 GS-R's used a P61.
Old Dec 18, 2003 | 11:20 PM
qtiger's Avatar
qtiger
You'll want to get a P72 asap... P30 doesn't fuel for a GSR's 2 stage manifold.
Your other option would be a Skunk2 manifold... :rick:
