smelling gas??
Old Dec 11, 2003 | 08:52 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Default smelling gas??
any suggestions on where to look?
when i'm sitting at idle after taking it to a higher RPM, i smell a hint of gas through my vents. any ideas???
Old Dec 11, 2003 | 01:21 PM
aphex's Avatar
aphex
driftin'
When im due for an oil change sometimes i smell small hints of gas randomly when starting up my car.
Old Dec 11, 2003 | 03:15 PM
teg_fan's Avatar
teg_fan
I like integra's
perhaps a bit of unburnt fuel in the exhaust going past your window? If thats possible.
Old Dec 11, 2003 | 03:35 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
See if you can spot any gasoline residue around your fuel filter...
If you haven't changed your fuel filter in a while, or if the bolts have become slightly untorqued, a little bit of gas leakage could occur when the fuel pump is providing more pressure at those higher RPMs
Old Dec 11, 2003 | 11:11 PM
ragerized's Avatar
ragerized
dc4 ownerages
yeah i have that same problem. i havent diagnosed it yet though. it happens when i take it like 5k rpms or past. i dont want to sound like a nub but, where is the fuel filter located?
Old Dec 11, 2003 | 11:37 PM
Epoch's Avatar
Epoch
Fuel filter is the black canister thing on the passenger side of the firewall near the battery. Should have one pipe running straight into the bottom, and another pipe bent at 90° coming out of the top...
Honestly though, I dunno if the fuel smell is EXACTLY that, but if you haven't changed your filter recently, and there's residue around the piping on the top, I don't think it could hurt (They're damn cheap, 20 minutes to swap out, and it improves milage...)
Though, it's a bitch to do it right...
Old Dec 12, 2003 | 07:03 PM
Kai's Avatar
Kai
Rotorphile.
Check all the fuel feed and return lines, the fuel rail and each injector. Just stick your nose in there and take a whiff, it'll be obvious if you have a leak. There will also be a bit of grime attracted to the area.
Old Dec 13, 2003 | 09:22 AM
redgsr98's Avatar
redgsr98
I had the same problem there was gas leaking from one of
my injectors because the o ring on the injector was damaged id check that out.
