is it possible to install a sub and amp to the stock integra radio?
Old Dec 10, 2003 | 03:33 PM
Clean00GSR's Avatar
Clean00GSR
B18c1 >*
Default is it possible to install a sub and amp to the stock integra radio?
does it have the correct inputs?? h:
Old Dec 10, 2003 | 08:12 PM
rgbpmp's Avatar
rgbpmp
No it doesnt have RCA pre-outs on the back of the deck.\
But you can hook the amp up to the rear speakers using the speaker level inputs on the amp (if equipped), you just run speaker wire from both your back speakers to the amp. Makes for very poor sound quality though.
The best way to go is to get a good aftermarket deck with rca pre-outs on the back.
Old Dec 10, 2003 | 09:11 PM
JGordon's Avatar
JGordon
Yeah, get a deck with RCA preouts. I hooked my Infinity Basslink up to the rear speakers, and while it worked, sound quality sucked. Rewired it to the RCAs, and it sounds much better.
Old Dec 10, 2003 | 09:20 PM
ChillOutWayne's Avatar
ChillOutWayne
well i had the same deal with me a while ago, i went and got a rca converter deal from the flee for like 10 bucks, then u tap into the rear speaker wires on the inlet of the converter, then plug yur rcas to the output, pretty simple and it acutally sounded real good
Old Dec 11, 2003 | 03:18 PM
rgbpmp's Avatar
rgbpmp
Depending on which amp you have, you might not need to get a converter.
Some amps accept the speaker wire right into the side, some use a small 4-prong plug.
If you amp does not have speaker level imputs (high voltage imputs) you would have to get the converter.
But getting a cd player with rca's is best.
Old Dec 11, 2003 | 03:37 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I would get a new head unit IMO... It would save you a lot of wiring pain, and you can probably get something that's better and has more features than your current headunit for like $150 and less...
Old Dec 13, 2003 | 09:28 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
Panasonic or JVC mp3 player for 199.99 @ circuit city. But seriously dont get them if you plan on having them for a while. i would advise you to get nothing less than pioneer, alpine or kenwood.
Old Dec 13, 2003 | 09:34 PM
Epoch's Avatar
Epoch
My panasonic's been decent so far... every once-n-a-while it throws and error type 3 at me if I bump a CD in slightly before taking it out... usually takes the CD player about 15 minutes to do a self check and realize there is no disc, but that's happened like 3 times in a year...
Looks snazzy though, and sounds pretty clean...
Old Dec 13, 2003 | 09:52 PM
Shore 96 Teg
thats cool that uve had good luck with urs or floor model had to be replaced cause the track search buttons stopped working
Old Dec 14, 2003 | 01:53 AM
JGordon's Avatar
JGordon
http://www.hookedontronics.com/show_...s.jsp?cid=3355
Panasonic 200 watt CD/mp3/WMA player, $140 dollars. I love mine -- RCA preouts, sweet looking face. Doesn't have a digital EQ and is a little slow to suck in CDs, but perfect otherwise. Sounds great.:thumbup:
Edit -- this is probably the one Shore 96 Teg was talking about for $199 at Circuit City, just significantly cheaper.
