Missfiring Integra problems
Old Nov 5, 2003 | 02:35 AM
firstfrd's Avatar
firstfrd
Default Missfiring Integra problems
I'm new to the forums and hope that someone can help me out with a problem. I own a 99 GS-R, and am getting some strange missfiring problems. After I drive my car for about 10 minutes I get this strange lag in acceleration. I changed the spark plugs and fuel filter, but the problem still persists. I checked the compression in the cylinders and that is at 120 and only needs to be at 100, so thats fine as well. If anyone could give me any help I would appreciate it.
File Type: jpg
Old Nov 5, 2003 | 02:46 AM
g2tegls's Avatar
g2tegls
MR, ftw
could be anything really. you check your ECU for codes?
Old Nov 5, 2003 | 02:47 AM
firstfrd's Avatar
firstfrd
No I havent checked the ECU Codes, I'll take a look tomorrow, thanks.
Old Nov 5, 2003 | 02:49 AM
g2tegls's Avatar
g2tegls
MR, ftw
Sure. Only time that ever happened to me it was a bad O2 sensor but not necessarily the same for you especially since your car is quite new.
Old Nov 5, 2003 | 05:22 AM
kfar09's Avatar
kfar09
just making sure but you are running premium gas right?
Old Nov 5, 2003 | 10:20 AM
firstfrd's Avatar
firstfrd
yeah, I'm running premium gas. Its weird, because sometimes it runs really smooth. But as soon as i go into the higher rpm ranges it starts to run funny in the lower ranges. Also, the check engine light will come on if I let it idle for 10 to 15 minutes. But the next morning when I start it, the check engine light will be off.
Old Nov 5, 2003 | 12:04 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
Grab that code when the CEL is on...that is a wierd problem though.
Old Nov 5, 2003 | 02:27 PM
Taiwanze7's Avatar
Taiwanze7
once the CEL is activated, it should stay on until you clear the battery. If you pull code 71-74, that means the cylinders are misfiring (I'm still having that problem)...
Old Nov 5, 2003 | 10:06 PM
firstfrd's Avatar
firstfrd
I actually found out today that the compression in cylinders in the gsr should never drop below 135, and should be running standard at 270 psi, so I definnetly have a problem in that cylinder.
