95 GSR Trouble Code 43
Old Nov 8, 2012 | 03:41 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default 95 GSR Trouble Code 43
My Integra is throwing a 43 code which is "fuel supply". Seems to be running fine, but has been using a little more fuel then normal.
Any idea's?
Old Apr 9, 2014 | 11:45 PM
Future Swap's Avatar
Future Swap
try the o2 sensor
Old May 27, 2014 | 06:59 PM
guitarswheelies's Avatar
guitarswheelies
Haha my latest car purchase, a '94 LS, is throwing the same code.
It only seems to come on when the car is cold and I use anything other than minimal throttle. I can shut the key off and restart the car within less than a minute and it goes out.
In other threads I've read 02 sensor, fuel pressure regulator and fuel pump if yours is aging. I code chart also says something about a vacum leak. Someone mentions the filter as well if it was never changed.
My car isn't getting the greatest mileage but it OK. I have the 02 sensor and will change it shortly. I'm gonna check the FP and will change the filter and possibly the pump. I might have a pressure regulator from another car to use.
Old Sep 9, 2015 | 07:39 AM
trm4life's Avatar
trm4life
trm4life
Sounds to me like the air temp sensor. Its pretty cheap and real easy to replace.
