Basically hook up the harness piece by piece and attach the similiar plugs. I'd start with the injectors because that will give you an idea of where to start.
everything plugs up to the engine. the si harness has 2 plugs for the ecu on the engine harness and the 3rd one is on the under dash harness.96-98 has all 3 plugs on the engine harness. how can i make that work
you cant use the 99 si wire harness becuase it only has the 2 plugs for the ecu,i guess you could but you goin to have to replace the hole wire harnees under the dash,i was goin to use a99si wire harness for mine,but i didnt because of that reason,i used my stock dx harness and wired vtec i hope this helped you
ok i used the stock harness. but my car will not rev past 4,000. im getting cel, 4,7, 91, crank angle. did you have any problems with yours. im using a 97 ex ecu
