Infinity Perfect 12.1d subs--- need help picking amp
Old Sep 30, 2003 | 05:27 PM
j_leininger's Avatar
j_leininger
Default Infinity Perfect 12.1d subs--- need help picking amp
Alright Im going to order Infinity Perfect 12.1d (dual voice coil) subs and I was just wondering what I need to look for in an amp cause all the amp numbers are confusing to me
RMS for the subs is 75-350watts
(peak 1400)
I would like to run the subs up as close to 350w RMS as possible(maybe just 250-300????)
I just need help as far as how many channel amp to get...etc. etc.
thanks
Old Oct 1, 2003 | 11:37 AM
arch iceman's Avatar
arch iceman
How many subs are you going to use total and do you have a budget for the amp? Typically you can get a 2 channel amp or mono amp depending on how you want to wire up the subs.
Old Oct 1, 2003 | 09:47 PM
j_leininger
I'm going to use two 12's....I would like to wire them so that the amp sees 2ohms.....as far as budget for an amp id like to keep the price down but at the same time get something decent.....prob. under 300 i'd say for the amp
Old Oct 1, 2003 | 10:12 PM
j_leininger
Old Oct 2, 2003 | 08:57 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Try the JBL bp 1200, you can find 'em on ebay for $250 brand new. With 2 2ohm subs, you'll be putting 600 watts RMS to each sub. Of course, you'll probably blow your car apart!!
