How to get rear main seal out of its ring?
I'm assembling my engine, and I'm ready to put in the new rear main seal. What's the best way to knock the old seal out of the metal ring? Should I install the ring onto the block, and then swap seals?
i pried the seal out with a small screwdriver. tore up the seal but what should you care since its being replaced. tap in the new seal to flush. i didn't have the correct tool honda recommends but at flush it seals just fine. install rings last. good luck
v
v
