FS: 94 Integra LS turbo with built motor
It's time I sell my car. As much as I don't want to, I have other priorities in life now. First, I must say that the car does not have a ECU right now. Two weeks ago, my AEM EMS died on me, so the car won't start right now. I am 110% positive that this is the problem, because I hooked up a stock LS ECU into my car, and it started up immediately. Everything was installed in July 2003, and everything has only 2600 miles on it. The body has a few dings on the passenger side from other peoples cars, but, overall, the body is in very good shape for being 9 years old. The interior is in very good shape. The body has 151,xxx miles it. Here is what's included:
B18B motor
Darton Full Iron Ductile Sleeves with a 3.209 oversize
JE 9.6:1 pistons
Eagle Forged Rods
All new rod and crank bearings
Balanced and Blueprinted
ARP head studs
new OEM headgasket
Skunk 2 intake manifold
AEM fuel rail
RC engineering 440cc injectors
AEM Fuel pressure regulator
Fuel pressure gauge
Walbro 255 inline fuel pump
Skunk cam gears
1996 GSR transmission
KAAZ 1.5 way Limited Slip Diff
ACT heavy duty clutch
PWR radiator
Short shifter/bushings
XS Engineering T3/T4 Ball bearing turbo
Tial wastegate
Blitz BOV
Sparco intercooler
Blitz SUS filter
3" Thermal Catback exhaust
3" Hedman Free flow cat
AutoMeter Boost/EGT/Oil Pressure/Water Temp gauges
Greddy Profec B boost controller
Greddy Turbo Timer
H&R springs
Bilstein Shocks
Brembo slotted/crossdrilled rotors
AXIS brake pads
22mm Type R rear sway bar
Type R front upper strut bar
RAZO pedals
AEM EMS standalone ECU(Doesn't work anymore)
Comptech Type R front lip
OEM sideskirts
99-00 Si rims with Michelin tires(60% tread left)
Two JL Audio 6" speakers(front)
Two Eclipse 6" speakers(rear)
Two Rockford subwoofers
One 2 channel Premier Amp
One 4 channel Premier Amp
Carbon Fiber interior
Tinted windows (35%)
I am not including my CD player that is currently inside the car. I just can't part with it, but I will give you the stock radio if you want it. The Kosei rims in the picture are NOT included. The car will come with the 99-00 Si Rims instead. I gaurentee you that this car is in perfectly operating condition. If you want to bring an ecu with you to see that it starts up, go ahead. I have absolutely nothing to hide. I have never taken it to the track, so I couldn't tell you exactly how fast it is.
$8200 with the Si rims
$8000 with the black steelie rims
Email me for pics, or check out http://www.honda-tech.com/zerothread?id=617691
I have pictures posted there as well.
B18B motor
JE 9.6:1 pistons
Eagle Forged Rods
ARP head studs
new OEM headgasket
AEM fuel rail
Fuel pressure gauge
Skunk cam gears
PWR radiator
Tial wastegate
Blitz BOV
Sparco intercooler
Blitz SUS filter
Greddy Turbo Timer
H&R springs
Bilstein Shocks
AXIS brake pads
RAZO pedals
OEM sideskirts
http://cgi.ebay.com/ebaymotors/ws/eB...&category=5335
I had to put it on ebay to get more people's attention.
All it needs is a new computer. It'll start with a stock LS ecu. Again, i have nothing to hide. I am 110% positive that everything else in the car is in perfect working condition. The motor only has 2600 miles. That's practically brand new.
UPDATE: I will sell the car for $8200 with the Si rims. The Kosei rims will NOT be included anymore.
OR, you can have the black steelie rims for $8000. Two of the steelies have Yokahama Guardex snow tires on them with 90% tread left, while the other two have some bald tires on them with one of them being popped.
