Is it easy....???
Old Jul 16, 2002 | 08:24 AM
acuraintryder's Avatar
acuraintryder
Default Is it easy....???
is it easy to remove and install a car radio/stereo into your car manually, or should you get that done by a professional????
any thoughts??
Old Jul 16, 2002 | 08:29 AM
drdavidge's Avatar
drdavidge
where in jersey do you live? ill do it for you cheap if you live close, but if you have any electrical knowledge (knowing how to solder wires, etc) its pretty easy. either way, let me know, ill help you out.
Old Jul 16, 2002 | 09:51 AM
eclipse spanker's Avatar
eclipse spanker
In all honesty, its a piece of cake........You can do it yourself
Old Jul 16, 2002 | 10:15 AM
pnthr30's Avatar
pnthr30
It is very easy....just make sure to get the correct wiring harness at Best Buy, Circuit City, or any stereo store (about $15) and it is pretty much just a matter of matching colors....piece of cake. Save your $40 or whatever it costs, you can do it yourself.
Old Jul 16, 2002 | 01:18 PM
esgsr1's Avatar
esgsr1
It's pretty easy. Took me about 3 hours to replace the radio, run wiring for the amp and hook up the subs. (1st time in the Teg but not the first time ever) Just take your time and be careful. Be sure to get the wiring harness and dash kit.
This site has some useful Integra specific info too.
http://integra.cyberglobe.net/caraudio/diagrams/
Old Jul 16, 2002 | 02:00 PM
[Ne0]'s Avatar
[Ne0]
its pretty easy i think team-integra.net has a how to on it and u can use a home made harness and save $15
Old Jul 17, 2002 | 11:35 AM
acuraintryder
dr davidge ur about 1/2hr from me. so if i need any thing..ill talk to u.
Old Jul 17, 2002 | 08:39 PM
mikesudds's Avatar
mikesudds
supa dupa member
there is actually an easier way to do it also...
if your radio is a fairly new one...you can buy "smart cables"
one is for your oem harness...it has a universal plug on it...and the other one is for your aftermarket radio...it plugs into it and has another universal harness, they plug together and you're wired up...
you can get these plugs @ circuit city
hope this helps some...
if you need tips on how to get your radio out pm me... i am a sales counselor @ circuit city so i know a little bit about installing, and if i don't know how to do it, someone i work with does...so just le me know
hollatcha
mike
