Swap Help!!! Anyone!!!!
Old Sep 13, 2003 | 03:37 PM
95DXPhiladeph's Avatar
95DXPhiladeph
Default Swap Help!!! Anyone!!!!
does anyone have AIM that I can ask them a few questions about this swap... i'm ready to order my engine this week, but im concerned about mounts and a few other easy questions...
please let me know...
SN: EklipZxTribexFLH
Old Sep 13, 2003 | 04:35 PM
Spood's Avatar
Spood
Sucka
And this swap is...?
Old Sep 13, 2003 | 06:32 PM
gsr92hatch's Avatar
gsr92hatch
for a motor swap into a hatch (ex. droppin a B18C1 into a Dx hatch) would u need a custom made catback or could i just use the 92-95 catback 1w/o modification.........maybe ill just go uni mufler but id rather get some power out of it, and a better sound
Old Sep 13, 2003 | 08:17 PM
dantastic's Avatar
dantastic
cx power!
its best to buy a catback thats meant to go into the car, then go to a muffler shop to get the new engine's header and cat to fit.
i have a dc jdm header and brospeed exhaust, with a custom cat to fit between them. if i ever want to change my exhaust, i can buy any exhaust for a 92-95 si hatch
Old Sep 14, 2003 | 06:35 AM
gsr92hatch's Avatar
gsr92hatch
thanks alot man, i was hoping for a fairly simple solution like that, about how much would the custom cat cost, and could i use an aftermarket header like dc sports?
Old Sep 14, 2003 | 07:07 AM
95DXPhiladeph
I'm swapping a B16a2 Del Sol SI engine into my 1995 Civic DX Non Vtec Coupe...
JapanDomesticMotor.com doesnt list their swaps to come with mounts, so I looked up hasport and they have some nice mounts... however, do I need to buy the transmission mount too? the kit comes with a left, passenger, and rear mount. Then theres an extra transmission mount you can buy. Is it worth it?
So basically I'm asking if I need any of these hasport items...
Lower Transmission Mount???
B-Series Distributor Sub-assembly for 92-95 Civics and 92-95 Integras with B-Series VTEC Engines (JapanDomesticMotor includes a distributor, so I guess I dont need this???)
Complete Axels (Designed for use with hasport mounts) ???
Custom A/C Bracket (to keep your civic a/c) ??? (i bought an A/C bracket for the b16a off ebay, so I'll be able to use the new A/C in my car right???
Rear Engine Bracket???
Old Sep 14, 2003 | 01:16 PM
95DXPhiladeph
top
Old Sep 14, 2003 | 05:47 PM
dantastic's Avatar
dantastic
cx power!
http://tech.hybridgarage.com should answer most of your questions.
when shopping for a swap, make sure u know whats included for the price. mounts can easily run you another $200-$500. are u getting the motor from a USDM delsol vtec? then it should be a b16a3. the factory mounts should bolt right into your car, as well as the included A/C bracket, and harness. the shiftlinkage off a b16 delsol WILL NOT work. you'll need a linkage off an 94+ integ or 99+ si
Old Sep 14, 2003 | 08:16 PM
95DXPhiladeph
so do i need to worry about VTEC wiring?
if i buy the wiring subharness for the B Series VTEC from Hasport, that'll put the VTEC wiring in and i wont have to do it?!?!
im going to buy the hasport mounts anyway just for the hell of it... i just need to find out if i need to buy the lower transmission mount also...
as for the A/C bracket, I think it's included in the swap, but I'm going to find out... if not... hasport also offers that...
Old Sep 14, 2003 | 08:21 PM
Nelson's Avatar
Nelson
Administrator
You have to wire VTEC from the solenoid to the ECU in order for it to actually work. B16 w/o VTEC is... :sad:
Hasport mounts are good, but I decided not to go for them because I was afraid of engine vibrations throughout the cabin.
You might have to play around with the right A/C mount for your A/C unit. Certain ones will not work right.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
