I need a fluid spec, anyone have a manual?
Old Sep 12, 2003 | 07:02 AM
MustBeDaMonkey's Avatar
MustBeDaMonkey
Default I need a fluid spec, anyone have a manual?
97 integra gs, manual transmission. I don't have the manual for it.
I need to know what weight oil to put in my transmission. I remember my old (2nd gen) teg used regular gear oil, but I'm not sure about this car. I suppose I could call the stealer and find out, but I figured I'd try you guys first.
TIA,
Toe
Old Sep 12, 2003 | 07:15 AM
JimBlake's Avatar
JimBlake
My '95 called for 10w-30 engine oil. But sometime since then Honda came up with their MTF and that's what you should use.
Old Sep 12, 2003 | 08:20 AM
crxb16er's Avatar
crxb16er
honda mtl is just fancy 10w30 (regular oil) u can also use redline (another fancy type oil) i use regular pennzoil synthetic 10w30
Old Sep 12, 2003 | 10:47 AM
MustBeDaMonkey
Thanks, that helps a lot, :thumbup: but it leads me to another question. How many quarts are in there? Also, since I haven't been under there yet, is it possible to pour it in, or does it need to be pumped in? (I'm guessing it is the standard 2 plug setup, lower is for draining and higher is for filling)
Thanks again!
Old Sep 12, 2003 | 12:50 PM
Civic Type Sev's Avatar
Civic Type Sev
That's correct... upper one is for filliing and lower one is for draining. When I drained my B16 tranny it took just over 2 liters of honda mtf. I highly recommend the honda stuff because the ``fancy part`` is extra additives which will keep everything running smooth. I tried 10w30 in my d series tranny and it started to grind so I went straight back to honda mtf and have been using it ever since.
Old Sep 17, 2003 | 09:12 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
i think that honda mtf is actually 5w-30 though.
