which fuel pump?
I found this on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432285652
I wanna get a fuel pump that I don't need a fuel pressure reg. Easy install.
Any recomendations?
Any recomendations?
that fuel pump will work you can go as high as a 255 before needing a regulator. You could just do like I did get a stock Gsr pump since you have a stock motor My hatch runs low to mid 14`s with a 94 Gsr swap with I/H/E but I also have all the Gsr fuel lines on my hatch also. :thumbup:
I looked at your other post and you 60 ft times were not bad on street tires but only running 91 MPH is what makes me think its a fuel problem and if you have the stock cx fuel lines and pump thats got to be the problem. It seems like by the time slips you swap is not making the top end power that Gsr`s should make. Try the pump and let me know if it works.
Aright, thats what I was thinking. I am running the gsr fuel lines, but I think my vx fuel pump has 236,000 miles on it. Thanks for all your help. I'll get back to everyone when I go back to the track with my new setup.
Okay so I bought that pump on ebay and it should be coming within a week. Are these DIY directions good enough for the installation?
http://www.c-speedracing.com/howto/f...p/fuelpump.php
cx power!
yea 255lph is really over kill. you should run a fpr and gauge to make sure the 190 lph isnt pumping too much fuel to ur injectors. oem gsr pump is only around ~90lph
